Fix for RCS Problems in Google Messages
(Topic created: 08-07-2022 07:50 PM)
TheNewsHQ
Comet
Tips
For those who are facing with the RCS connecting problem or if it says Setting up etc just do the following and it should fix it
Go to the SIM card settings turn off your SIM card leave it off for a few seconds kill the Google Messages app, turn back on the SIM card and it should say connected within a few seconds
userGv5V6HKSZM
Cosmic Ray
Tips
It worked. Thanks.
Joeyjoe
Galaxy
Tips
Thanks
Blacc_Corleone
Tips
It sure worked for me also. Thanks
Matty77
Halo
Tips
Unfortunately this only works until you restart, or shut your phone off.
Zapp2211
Galaxy
Tips
You're right that's what happens when I restart my phone it goes back to connecting there's something with the beta that's making it like this I'm getting tired now I hope this gets drained out after the full version
Paul
Chrisrj8084
Galaxy
Tips
Yep worked for me thanks. Sucks gotta do it again after a reboot but at least it works for now. Hope they fix this in the next update
USBetaModerator
Beta Moderator
Tips
Hello,
Thank you for the valuable tip. We appreciate your contribution to the Beta community.
Regards
One UI Beta Team.
Tips
This worked thank you!
Zapp2211
Galaxy
Tips
Thanks 🙏👍 your right all this time I was trying to connect I'll call Samsung to give you a foldable phone just kidding 😂🤣🤣 thanks again
Paul
