Highlighted
Need replacement battery for NP900X4C A07US
JUMP TO SOLUTION
Hello,
The battery in my Samsung NP900X4C A07US laptop needs to be replaced.
  1. Can I buy a replacement from Samsung? If so, how do I find it and buy it?
  2. I’ve found replacement batteries online, including on ebay. Is it OK to buy a battery that is for the NP900X4C series, but doesn’t specifically specify A07US? Will that still work fine, or well enough?
Thanks for your help!
1 SOLUTION
Highlighted
Honored Contributor
Re: Need replacement battery for NP900X4C A07US
JUMP TO SOLUTION
As long as the battery matches specs for the battery made directly for the NP900X4C-A07US then you should be fine to get one not directly made by Samsung. To purchase one from samsung you can visit www.samsungparts.com or you can call them at 800-627-4368.
2 REPLIES 2
Highlighted
Honored Contributor
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
Thanks!
