S21 Ultra Beta Charging Problem
(Topic created: 10-16-2021 09:11 PM)
seape82651
Cosmic Ray
Discussions
My phone will now only charge to 85 percent after the second update can anyone explain why I'm having this problem please
user751201tmO21
Honored Contributor
Discussions
Yea, it's a feature you can turn ON and OFF in the Settings
Settings > Device Care
Tap on the Battery section
Scroll down and tap on More Battery Settings
Protect Battery at bottom is what you're looking for
BTW, it's best to leave it on ... charging to 80-85% will allow the battery to live a longer life, overall
Charging a battery to 100% constantly, will kill a battery in short time (reduce its overall life expectancy)
USBetaModerator
Beta Moderator
Discussions
Hello @seape82651 ,
Please check settings -> battery and device care -> Battery -> More battery settings -> Protect battery is enabled. If setting is not enabled and device still stops charging at 85%, Please update Samsung members app to latest version from galaxy store and send us an error report immediately after experiencing the issue from the Samsung member’s app -> Beta Feedback -> Error Reports to help us debug the issue. We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
