Work Around foR eSIM Problem
(Topic created: 09-16-2021 01:30 PM)
rdinsf
Halo
Discussions
There are numerous reports that the eSIM functionality is broken.
J0SEPHMATTHEW
Galaxy
Discussions
Yeah I had a brief pop up of a SIM when I touched the beta app after singing up then the app went away LoL that's beta & they'll fix it
Discussions
Ya doesn't work yet. Probably gonna have to wait for a beta update. Hopefully it's the next update
user_ams007
Planetary Samsung Care Ambassador
Discussions
I am sure that it will be fixed soon
USBetaModerator
Beta Moderator
Discussions
Hello @rdinsf ,
We are working on resolving the issue and will notify as part of our software update notice when it resolved.
Please try working with carrier again after checking next software update.
Regards
One UI Beta Team
rdinsf
Halo
Discussions
Here. is another problem with the eSIM implementation. I have it working by using the SIM switch technique in the Reddit link above. However, a problem - the SIM Manager app outside the US allows you to set different default primary SIMs for voice, SMS, and data. The version in the beta only allows you to set a SIM as primary for everything. In other words you have to have the same primary for voice, SMS, and data. This is a problem, as a common use case is one SIM is set primary for data, and another for voice.
That can't be done with the beta. In my situation, I have a data only SIM for data. I have to set that as primary to use the data. But voice calls fail because the phone tries to put the calls through the data SIM because I can't set a different SIM for voice and data.
Again, this can be fixed by by offering the options in SIM Manager as offered in other markets.
