galaxy Note 10 battery issues
(Topic created on: 3/18/21 3:56 AM)
MzRaiderette
Galaxy Note Phones
I notice after the Android  11 3.0 software update the battery on the Note 10 drains a lot faster.  The phone is a new. Anyone else having the same issue? Any tricks to help battery  life last longer besides the power saving mode. Anything helps. Thanks.
Incog
Galaxy
Galaxy Note Phones
I debloat mine, but that's not for the faint hearted. Try disabling some of those useless apps on your device.
Also, sometimes a factory rest after a major update can help, but I would wait on that until the 3.1 comes out first. This Android 11 is a really buggy update for a lot with screen rotation failing and sensors randomly stop working.
Its been a disastrous update from my experience.
KingRizz
Galaxy Note Phones
My battery is dying faster than normal. what can I do  to make my battery go back to normal?
LongHiker
Samsung Care Ambassador
Galaxy Note Phones
@KingRizz
First of all determine if an app is causing the battery drain. Open Device Care, click on Battery, click on the graph. It will show you how much battery each app has used. You can look at it from last full charge or last 7 days. If an app is using more battery than you expected, stop or remove that app.
