Fit 2 wont connect to Flip 3 phone
(Topic created: 08-28-2021 10:01 AM)
Jaystarrockzz
Galaxy
Gear and Gear Fit
Is anyone having issues connecting their galaxy fit 2 watch to their Z flip 3? It won't connect just shows the loading circle. The watch connects on other devices but not the z flip. I tried all options including erasing cache and memory and still no luck. Is it a phone issue? Does samsung have to update something on their end?
1 Reply
Jaystarrockzz
Galaxy
Gear and Gear Fit
Solving my own issue I learned for some reason having the Bluetooth and wifi on together causes some interference when connecting certain devices. I uninstalled the wearable app and re downloaded it. Next I turned off wifi and starting from scratch connecting the Fit 2. Bam! It worked well. Hope this helps others if you have connecting issues with other watches etc
