Highlighted
Re: Unable to connect my Gear S3 to Gear app on my phone.
JUMP TO SOLUTION
Count me in as well.
Just got my Frontier watch today from Samsung and no way to pair it up or use it Smiley Sad
Highlighted
JUMP TO SOLUTION
@userdeTjF4NhPK; Hey, what type of phone are you attempting to pair the Gear with? If you can provide me with the full model code, baseband, and carrier information; I would be happy to look further into the issue for you.
Highlighted
JUMP TO SOLUTION
My watch connected to my phone for the 1st week but hasn't been able since. Into the 2nd week some joke...
Highlighted
JUMP TO SOLUTION
Any ideas on why it's not working
Highlighted
JUMP TO SOLUTION
Are you using Android P?
Highlighted
JUMP TO SOLUTION
9/30/2018.i have a note 8 and had same issues,i clear memory,remove wearable app and reinstall app,and run set up again and it worked. I try several times before last step, finally removing it and reinstalling did it. <hidden>
Highlighted
JUMP TO SOLUTION
did this many times, plugins, reset watch, cleared cache and data, removed app and reinstalled,  removed bluetooth connection then reconnected, installed latest os on phone. no dice, same problem. was never able to complete the setup.
says its pairing, setting up, completes %100 during setup, but then hangs and never finishes. I see the phones bluetooth indicator show it connect for about 5 seconds then disconnects while setup is happening.
old phone but should work.
s6 active
Highlighted
JUMP TO SOLUTION
Actually, this alone did not do it for me. You have to be more radical than this.
1. On your watch, switch off BT.
2. On your phone, remove the pairing between the phone and the watch.
3. On your phone, delete cache and data of the Galaxy Wearable app.
4. On your watch, select "Pair with new phone" option. This wipes all user data on the watch in the process, and activates BT again. It should also cause your phone to launch the Galaxy Wearable app.
5. Follow the onscreen instructions.
6. Restore your Backup. If you didn't have one, make sure to make one in the future :-).
I know this is very radical, but I spent a whole evening trying all possible combinations, and this was the only one that worked.
Highlighted
JUMP TO SOLUTION
I am having the same issue on my Samsung Gear S3 Frontier.  Right now only Galaxy wearable is available for download on my Samsung S7 phone and I have downloaded it but cannot open / pair with gear S3.
Highlighted
JUMP TO SOLUTION
Is there a work around on the connectivity issue between Samsung Gear S3 and Samsung S7?
