Samsung TV no memory issue
(Topic created: 10-23-2024 05:07 AM)
Frustrated70
LED and OLED TVs
My Samsung TV is only a couple years old. It keeps giving me a message that there is no memory and that I need to delete apps. I deleted apps and cleaned out what I could, the message is still there. I called Samsung IT, they said I needed to buy more memory. Why pay so much for a TV just to add memory even after deleting apps? I'm starting to feel like some of the people that have made negative comments on here.
LED and OLED TVs
I have a few samsung smart tv's. I had a similar problem and was given the same answer. One thing you can do is use a firestick, which has its own memory to free up what's on the TV but ultimately, I did a total factory reset on my smart TV and ask the problems went away. Good luck.
LED and OLED TVs
meself
Honored Contributor
LED and OLED TVs
Updates and apps etc use memory like your phone
RobXbalboa
Red Giant
LED and OLED TVs
Go into device care on the tv and run it. It will free up alot of space by deleting all the old caches
sj7230
Supernova
LED and OLED TVs
The apps could be taking up lots of storage than it seems.
