Samsung AU8000 Not able to adjust sound
(Topic created: 04-11-2025 12:57 PM)
hjh1102
LED and OLED TVs
I have a Samsung AU8000 and occasionally I am not able to adjust the sound from the remote or the remote from the app.  The only way I have found to fix the problem is to unplug the tv and plug back in.  This issue seems to be happening more frequently, so I am wondering if anyone has any other suggestions for a fix.  Thank you.
Samsung_Moderator
LED and OLED TVs
Hi there, Thanks so much for posting about this. That does sound annoying. First, have you confirmed the software for both the TV and soundbar are up to date? Also, could you provide the type of TV and connection you're using? Lastly, have you had any other symptoms or issues?
hjh1102
LED and OLED TVs
Thank you for getting back to me.   I am not using a soundbar, it is directly through the TV.  It is a Samsung AU8000 65".
Samsung_Moderator
LED and OLED TVs
My apologies. Has the TV's software been updated? Also, just out of curiosity, do you have anything blocking the bottom of the TV? If not and the TV is updated a factory reset on the TV would be recommended.
