userYOIgyp5IvQ
Monitor uh750 not making sound
JUMP TO SOLUTION
I have bought the monitor uh750 from amazon and when I connect it by Displayport it does not play sound. I have run the troubleshooter and it does not have any new drivers. When I use an audio visualizer it shows that it is playing I just cannot hear it, my headphones work though.
1 SOLUTION
Re: Monitor uh750 not making sound
JUMP TO SOLUTION
Are you connecting headphones to the monitor? The monitor does not have speakers.
6 REPLIES 6
JUMP TO SOLUTION
Are you using an adapter for the Displayport?
userYOIgyp5IvQ
JUMP TO SOLUTION
No, just 1 cable
JUMP TO SOLUTION
Is it a Displayport to Displayport cable? Please provide the full model code of the unit. Are you sending the sound to your headphones?
userYOIgyp5IvQ
JUMP TO SOLUTION
Yes, it is a DP to DP cable. The full code is LU28H750UQN
JUMP TO SOLUTION
userYOIgyp5IvQ
JUMP TO SOLUTION
Oh, I thought it had speakers
