New Monitor U32R590CWN Blue Led Power light
(Topic created: 01-08-2020 02:28 PM)
userXwpD2WTX3D
Monitors and Memory
I just received a U32R590CWN monitor and everything seemed okay. According to the Owners Manual the little blue power led light is always on even when the monitor is turned off. This was the case over the last couple of days and today when the monitor was on the little blue light has gone out. When the monitor is turned off it goes back on. The led light flashes intermittently when searching for a signal and that condition is normal. The monitor is still within the return period and if this is a problem I will return it. I have tried a displayport cable and the HDMI cable that came with the cable and still the same results. The monitor power cable is plugged into an outlet and the monitor has been set back to factory settings. I am using a Nivida RTX-2070 Video Card. Any ideas's?
SamsungLou
Monitors and Memory
The LED settings may have been inadvertently changed in the monitor menu. The following excerpt is from page 10 of the user guide.
1 Reply
SamsungLou
Monitors and Memory
