Samsung_SPgdyzu
My phone has been losing battery really fast and charges really slow
1 SOLUTION
Wheezie
You might want to make sure apps are closed before you ch...
JUMP TO SOLUTION
You might want to make sure apps are closed before you charge it. Sometimes you could have 2-3 apps running in the background & that will keep it from charging. Mine use to always say weak charge, then I found out Chrome never closed & it kept running in the background.
13 REPLIES 13
Re: Battery
JUMP TO SOLUTION
Hey there,
Thanks for reaching out. May I ask what type of device are you using? Have you tried optimizing your battery recently?
Samsung_UxSJbhU
My Samsung galaxy s5 is loosing battery rapidly
JUMP TO SOLUTION
Joshua1394
My s10+ has been doing the same
JUMP TO SOLUTION
Samsung_MkYmerz
Mine is doing the same thing literally my phone has been...
JUMP TO SOLUTION
Mine is doing the same thing literally my phone has been on the charger all evening and it's only at 18% now I have try to optimize it and it did nothing to it I'm o. A galaxy j7 what eles could I do
Honored Contributor
Re: Mine is doing the same thing literally my phone has been...
JUMP TO SOLUTION
Does the battery drain fast while the device is in safe mode?
userbdrNYOJqmV
Mine as well
JUMP TO SOLUTION
Mine as well
User55786
Cosmic Ray
What device is it? And do you have a 3rd party charger
JUMP TO SOLUTION
Samsung_eh1OhvY
I'm using the Samsung galaxy s8+ and it's not charging fa...
JUMP TO SOLUTION
I'm using the Samsung galaxy s8+ and it's not charging fast as it use to be.
userPHZiyaVCTd
Re: I'm using the Samsung galaxy s8+ and it's not charging fa...
JUMP TO SOLUTION
I have the Galaxy s8+ too. Mine started failing a few days ago at charging. I've stopped all the background apps, I've optimized with some thingy to click on that frees up something. The phone came with two charging things. I have the cord, I have the little piece that fits into the phone, but did a male to male thing come with the phone that inserts into that second non-cord charging thing?
I just got a fake new cord. It fits more snuggly like the original cord fit.
my phone is charging better than it did before the new cord.
This doesn't explain why the phone would not hold a charge however as of a few days ago.
