Showing results forĀ
Search instead forĀ
Did you mean:Ā
Wifi network speed is slower in 1ui 4 beta than in 1ui 3.1
(Topic created: 09-30-2021 01:28 AM)
anonym0us
Halo
Questions
My galaxy s21 phone is getting slower wifi speed in 1ui 4 beta than in 1ui 3.1 it used to get around 800 - 900mbps wifi speed but now with our currently upgraded internet home speed with xfinity at 1200mbps my galaxy s21 1ui 4 beta only gets around 500mbps can they fix this
Coldheat06
Galaxy
Questions
Good catch I just tested my wifi speeds and it has definitely slowed down. In my house all of my other phones are getting over 415mbps but my S21 Ultra is barely getting 300mbps
Be sure to click " āœ“ Accept as Solution" when you find an answer that works for you.
user_ams007
Planetary Samsung Care Ambassador
Questions
Have you tried to completely remove the wifi profile from settings and then reconnect to the same network, but make sure that you have use phone Mac address and not a random address
Not applicable
Questions
Yes I have had the same issue
user_ams007
Questions
I am using a Asus Ax10000 router with a 1gig fiber optic connection and I constantly connect to my Router at 2.2g, check your routers settings that may help Screenshot_20210930-132540_Settings_12214.jpg
USBetaModerator
Beta Moderator
Questions
Hello ,
Thank you for your feedback. If you havenā€™t already, Please update Samsung members app to latest version from galaxy store and send us an error report immediately after experiencing the issue from the Samsung memberā€™s app -> Beta Feedback -> Error Reports to help us debug the issue. We apologize for the inconvenience and appreciate your contribution to the beta program.
if available, also attach screenshot of Wi-Fi speed from a different device on One UI 3 camping on same WiFi network to the error report.
Regards,
One UI Beta Team
anonym0us
Halo
Questions
I just checked my wifi profile on my galaxy s21 1ui 4beta phone and now it currently says that the speed is 1.2gig where before it wasn't even half that and I did a video showing the speedtests between the speedtest.net website and the speedtest.net android app the website speedtest result was that it peaked at around 500mbps and ending between 100 and 300mbps and the android app speedtest result was that it was between 700mbps and 900mbps out of my 1.2gig internet speed that we pay for I'm confused if it's a 1ui 4 beta bug or whatScreenshot_20211001-032517_Settings.jpgScreenshot_20211001-034408_Chrome.jpgScreenshot_20211001-034252_Speedtest.jpg
