Hitgirl617
- Mute
11-28-2020 09:52 PM in
Galaxy S20
Is there anyone here also experiencing the volume of the samsung s20 fe change in to low even if you put it to 100%? And then when I restart the device it will go back to the normal loudness. I'm actually starting hating samsung for this so many bugs.
Solved! Go to Solution.
Pastafarian
Halo
- Mute
11-30-2020 06:24 AM in
Galaxy S20
Settings>sound and vibration>volume>click the hamburger menu (upper right)>media volume limit. Turn it off.
damion36
- Mute
11-28-2020 10:01 PM in
Galaxy S20
it's a safety feature that's always turned on
Hitgirl617
- Mute
11-28-2020 10:06 PM in
Galaxy S20
what you mean safety features? Its a bug its just randomly happen out of the blue. Like when you are browsing fb and you watching video even if you put the volume to 100% its sound like its on level 3
damion36
- Mute
11-28-2020 10:58 PM in
Galaxy S20
it's in sound settings
Pastafarian
Halo
- Mute
Galaxy S20
