One ui 7 battery issues
(Topic created: 05-25-2025 02:48 AM)
userzYs8NtlkUK
Fold & Flip Phones
Hi from Switzerland,
Since I did the One UI 7 update on my Galaxy Fold 6, my battery lasts half a day. I no longer have super-fast charging, so it's a double problem.
I have to use power saving mode to use my phone normally. That's not normal for a phone that I bought in October 2024.
1 Reply
realaud
Honored Contributor
Fold & Flip Phones
You have landed in the forum where the focus is on U.S. device models.  You might find more help in the forum for your country.
https://www.samsung.com/visitcountry/
That being said, I understand that Samsung is aware of the battery issue and currently working on a fix.  When it will be available is anyone's guess.
Please mark any response that helped you as your solution.
