Changing phone location without using VPNs
(Topic created: 03-10-2026 03:09 PM)
MindWr4ith
Cosmic Ray
Galaxy Note Phones
I want to move to Canada (not saying where for privacy reasons). But since I live in the United States for now I have to go under different apps (or calculator just to transfer USD - CAD) just to see the Canadian currency and I would like to change my location to Canada to see if I can view things in CAD (Canadian Dollars) and not in USD. This is annoying, yes. However, if I need to actually move before I'm able to fully view things in CAD. Then I can go for 6 months (as that's the max I'm able to stay) and change my address to where I temporarily move to in Canada while still having my United States address as my "main", as again, I'm not living in Canada, just moving temporarily.
Any help is great. I don't really know much about technology anymore so I'd rather not use VPNs as I'm trying to save up for my trip to Canada and get everything I'd need to comfortably live at my place in Canada. I can provide pictures in comments, but my location seems to be locked in the United States (understandable, but a little annoying).
I am on the Samsung Galaxy Note20 Ultra for anyone that needs to know.
Mujibar
Honored Contributor
Galaxy Note Phones
You can't change your device location without a VPN.
Mujibar
Honored Contributor
Galaxy Note Phones
MindWr4ith
Cosmic Ray
Galaxy Note Phones
Yeah, unfortunately I thought that was the only way. It'll be easier for me to just use the calculator app to view USD -> CAD.
Thank you for the assistance.
Mujibar
Honored Contributor
Galaxy Note Phones
You're welcome. Good luck!
