Battery drain overnight (Android 14)
(Topic created: 03-16-2024 05:38 AM)
HossainAbeer
Galaxy S21
Hello, at night, I charged up the phone to 81%, cleared all the apps in background, turned off all radio except the cellular network. In the morning, i checked the battery drain to be 8% while idle overnight.
What about yours? Is this normal for those who updated to Android 14? See screenshot for reference
HossainAbeer
Galaxy S21
Update: i put it on flight mode, and overnight the drain was just 3% which is quite normal. So it has gotta be the cellular network.
I changed the connection between 4g, 3g, 2g several times and lastly turn off auto select for network operator and manually selected it.
This time with cellular turned on, overnight was just 4% which is quite normal
If you're facing similar issue, give it a try
โ€ƒ
โ€ƒ
โ€ƒ
โ€ƒ
HossainAbeer
Galaxy S21
Hey thanks for responding, but that doesn't say anything about my question: is 8% drop during idle overnight a common thing for those who updated to 14?
Please do share your condition if you've updated
BIGMAMA55
Galaxy S21
Put dem bad boys to sleep
NicoNi4Lyfe
Galaxy
Galaxy S21
Fold 5 here and sounds right.....I am losing 6% from a full charge to wake up.....don't even know why ๐Ÿ˜ถ
HossainAbeer
Galaxy S21
โ€ƒ
โ€ƒ
โ€ƒ
โ€ƒ
