Ice dispensing issues
(Topic created: 01-29-2025 11:36 AM)
Tayfraz
Kitchen and Family Hub
How do you remove the ice bin inside the Samsung mega capacity refrigerator?
1 Reply
GaryB82
Galactic Samsung Care Ambassador
Do you have a model number for the Refrigerator if its model# RF32CG5100SR / RF32CG5100SRAA
Page 64 of the owners manual lists theses steps
1. To remove the ice bucket, gently lift it
up, then pull it out slowly while holding
the bottom of the bucket with one hand
and the side with the other hand.
2. Empty the bucket.
3. When done, put the bucket back into
position. If the bucket does not fit in,
turn the helix screw 90 degrees, and
then try again.
If the ice bucket is not firmly inserted,
turn the Helix (A) 90 degrees, and then try
again.
4. After putting the bucket back into
position, gently pull it down and make
sure it is firmly sitting on the slot.
If you've found my post to be helpful, Please like my Comments āœ“āœ“āœ“.
If my response resolved your issue, please press the Like and āœ“āœ“āœ“ to Accept as Solution button.
