- Mute
09-25-2022
01:19 PM
(Last edited
09-29-2022
07:46 AM
by
SamsungJecca
) in
For future dishwashers, please consider adding a locking mechanism, similar to the one for clothes-washing machines, when a washing cycle is in progress.
Solved! Go to Solution.
- Mute
09-26-2022 07:16 AM in
KitchenHi there, Thank you so much for the suggestion! I believe some of our dishwashers do have a door locking mechanism, and I can certainly understand the need for this. Samsung appreciates your feedback as it helps us to continue working to improve the overall customer experience.
- Mute
