- Mute
โ09-13-2025 11:23 AM in
LED and OLED TVsI have a 43โ Frame QLED 4K Smart TV (2021) QN43LS03AAFXZA I believe it's had a hardware failure as there are lines across the screen and I've already done all other suggestions and hasn't resolved. My question is, does the newest model still use the same wall bracket? Would make things A LOT easier if that didn't have to be replaced as well.
- Mute
โ09-13-2025 12:34 PM in
LED and OLED TVs@RichardNJ Which wall mount do you currently have
If you've found my post to be helpful, Please like my Comments โโโ.
If my response resolved your issue, please press the Like and โโโ to Accept as Solution button.
- Mute
โ09-13-2025 12:53 PM in
LED and OLED TVsI attached it to the wall 4 years ago so really don't remember exactly... whatever the slim one is that comes with that model tv. I just want to make sure the new model uses the same wall mount since it was a real challenge to get it attached to the wall and prefer not having to change that too.
- Mute
โ09-13-2025 03:21 PM in
LED and OLED TVsIf you've found my post to be helpful, Please like my Comments โโโ.
