Rebooting loop
(Topic created: 03-15-2025 01:05 PM)
Sopu
LED and OLED TVs
Hi! I know there has been at least one other person asking this, but i couldn't fix my tv with the advice he had been given, so i'm asking what to do then. So thw tv will look broken first, part of the screen going black and green, and then it turns of and then on again, only to repeat it.
I did the 5-10 min unplugged, but cannot reset the tv, because it starts the reboot loop so fast. I've taken out all other things like hdmi etc. What to do next?
Thanks.
Samsung_Moderator
LED and OLED TVs
Hi, Sopu. Welcome to the Community! We know how frustating it can be to have a rebooting loop on your TV.
Have you tried a factory reset on your TV? Here are some steps to help you.
To perform a hard reset (factory reset) on a Samsung TV without a working screen, you'll need to unplug the TV, press and hold the power button for 30 seconds, then plug it back in and power it on.
Lets us know if this helps!
Sopu
LED and OLED TVs
There r no buttons on the tv... I did that with the remote, but don't think it's the same. A professorional tv-fixer said that he thinks the led-panel has broken and it would be cheaper to buy a new tv than to fix this.
Samsung_Moderator
LED and OLED TVs
Do you have a model number for the TV? With a model number i'll be able to further assist you.
