Smart Clean Washing Machine - SmartThings Issue
(Topic created: 02-27-2026 11:02 AM)
jpel84
Laundry
I recently got a Samsung washer/dryer set. I'm trying to find the app for the smart care so I can set it up. Smart things says the device isn't supported (although that's what the manual says to do). The smart care app doesn't open and there is a Samsung laundry app that another manual says to download. What has everyone done?
Samsung_Moderator
Laundry
Hello, jpel84, Welcome to the Community; we're glad to have you! We understand your concern with connecting your Samsung Washer to SmartThings, and we want to help you.
We researched SmartThings and the washer. With our newer appliances, there may be a small QR code on the front of the washer. Normally, that QR code is near the top left or right corner of the washer.
And we believe this guide will help with getting your washer set up with SmartThings
https://www.samsung.com/us/support/answer/ANS00082522/
Here is a link for more information on the SmartThings app:
https://www.samsung.com/us/apps/smartthings/
To confirm if your washer is compatible with SmartThings we would need to have the model number of the washer. please feel free to provide it, and we'll be glad to check if your washer can connect to SmartThings.
If you find that your washer is SmartThings compatible but you're having an issue with SmartThings, please feel free to reach out to our SmartThings team at this phone number: 866-813-2404.
Please let us know if this helps.
1 Reply
Samsung_Moderator
Laundry
