Top Load Washer will not start
(Topic created: 05-17-2024 10:33 AM)
ShawnaRKay
Laundry
Samsung 4.0 Cu. Ft. Top Load Washer With ActiveWave™ Agitator And Soft- SKU/Model #: WA40A3005AW
Will not start.worked fine just before.  Powers on.  Will allow me to set my settings but when I push start all lights light up and hot water temp flashes with rest on settings lights on. It also beeps. I plugged unplugged checked circuit tried several times to start and nothing changes. Please help. I bought it used no warranty
Samsung_Moderator
Laundry
It sounds like the child lock may be engaged. You can use the following link to find out how to engage/disengage the child lock: https://downloadcenter.samsung.com/content/UM/202306/20230630150554027/DC68-03850F-04_IB_WA3000A_EN_...
If the above troubleshooting steps didn't help you would need to speak with one of our moderators via private message. Service would be required to resolve the situation, however, if you've already had service multiple times and the issue continues, We would need to review your case further so ask that you send us a private message as well.  Please feel free to reach out to us directly via one of the following options and with a link to our thread along with your full model and serial number.
Facebook Messenger: http://m.me/samsungsupport
Twitterhttps://twitter.com/messages/compose?recipient_id=18768513
Or you can use the following link below to request service. https://www.samsung.com/us/support/service/
1 Reply
Samsung_Moderator
Laundry
