Option/Feature Request For Saving Pro Mode and Pro Video Settings
(Topic created: 01-27-2023 11:49 AM)
Zane99
Halo
Legacy S Phones
Sometime possible I would like to see a feature or an option to backup/save/import/export Pro Mode and Pro Video manual settings in case of software update, smart switch transfer to another phone or factory reset resulting in default. This would save so much time and energy instead of resetting them each time. I love being in control of how my pictures/videos turn out manually. Sometimes I don't want the perfect shot, I may want to change something at any given moment.
Samsung_Moderator
Legacy S Phones
Thank you Zane99, for your interest in sharing your great idea with Samsung. We appreciate your feedback and will tag it on the forum so that it will appear with other feedback, ideas, and requests. This will allow your post to be more easily found in the event that Samsung product groups are seeking outside feedback/requests/ideas regarding our products.
userRn4YefmXfz
Legacy S Phones
Expert RAW app supports this feature currently.
Zane99
Halo
Legacy S Phones
I need a feature/option that's more direct when it comes to this. A real permanent backup solution for my manual settings is needed. The expert raw version is half the slice,I need the whole cake.
Samsung_Moderator
Legacy S Phones
