Vertical lines screen problem
(Topic created: 09-28-2025 01:35 PM)
kbwis
Legacy S Phones
Why is there a vertical line on my screen?
MrGhoul
Neutron Star
Legacy S Phones
Check out the link below
https://www.androidtipster.com/how-to-fix-vertical-lines-on-android-phone/
After trying all the steps to fix the vertical line, you may need to take it to a repair shop.
https://www.samsung.com/us/support/service/locations/
MrGhoul
Neutron Star
Legacy S Phones
kbwis
Legacy S Phones
Thank you
