Lelab144
- Mute
‎02-08-2021 11:18 PM in
Note20
I have my notifications turned on but my apps aren't notifying me of text messages
Solved! Go to Solution.
userJMZrkNG0Fq
- Mute
‎04-13-2021 11:04 AM (Last edited ‎04-13-2021 11:05 AM ) in
Note20
I have the S21 and had the same problem. Open your messages, tap the 3 dots (right side above your texts), open settings, tap notifications then tap show notifications. It fixed mine. Hope it helps.
DD17
- Mute
‎03-01-2021 08:38 AM in
Note20
i have the same issue and can't get this to work no matter what I do.
userJMZrkNG0Fq
- Mute
Note20
Lelab144
- Mute
‎04-13-2021 11:25 AM in
Note20
Yeah looks like they finally fixed the issue, mine is working again too and I didn't have to do anything
