Battery Issue - Note 20 Ultra
(Topic created: 01-16-2025 02:59 AM)
Galaxy Note Phones
To those Note 20 Ultra Owners out there, have you had to replace your battery and if so, what or where did you go?
GaryB82
Galactic Samsung Care Ambassador
Galaxy Note Phones
I would suggest contacting a service center near you to change the battery that way you know you’re getting genuine parts
https://www.samsung.com/us/support/service/locations/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
GaryB82
Galaxy Note Phones
Galaxy Note Phones
Did you run diagnostics on it first? I still use mine every day, and the battery is the same as 4 years ago. I ran the diagnostics in this app on it. Just to see the state, no problems.
GaryB82
Galaxy Note Phones
They did it’s showing a weak battery issue per their screenshot above.
