How to Avoid Eye Strain While Using Samsung Phones?
(Topic created: 04-09-2026 06:37 AM)
emilyjohnson
Galaxy Note Phones
How to reduce stress and eye strain from using Samsung smartphones for long hours?
-CROW-
Supernova
Galaxy Note Phones
Settings
Display
-CROW-
Supernova
Galaxy Note Phones
Settings
Display
Robin621k
Honored Contributor
Galaxy Note Phones
No one should be looking at any screen for hours, it doesn't make a difference who makes the display.
AAbbott
Comet
Galaxy Note Phones
You avoid eye strain by lifting your eyes from the screen every so often and looking around at other things. Same way you need to get up and move every so often so that your leg muscles don't atrophy.
Diaboyos
Honored Contributor
Galaxy Note Phones
Turn on the eye comfort shield and dimming as well if it's dark.
jlgarber
Galaxy Note Phones
Even those of us that spend all day on our phones are not literally spending 10 hours staring at a screen. You blink, hear a bird and look up. Check on a child or animal every few minutes. Participate in zoom meeting, listen to a book or music while doing dishes or preparing a meal.
