Wireless PowerShare is missing from quick settings menu on Note8
(Topic created: 12-08-2019 03:53 AM)
usertLUIanEfwi
Galaxy Note Phones
Hi Guys,
I just baught a samsung galaxy active 2 watch and trying to wireless change it through my Galaxy Note8 device using PowerShare.
I am following the instructions and opening the quick settings menu from the top yet there is no "Wireless PowerShare" options.
Any idea?
Thanks,
Eibi
userJGRopDMI3U
Galaxy Note Phones
The Samsung galaxy note 8 does not support wireless power share. Only s10 and note 10
Esso
Cosmic Ray
Galaxy Note Phones
Hit the edit when the quick settings is open and see if it's set to hidden.
usertLUIanEfwi
Galaxy Note Phones
Thanks for the reply!
I do not have an Edit button in there..
userJGRopDMI3U
Galaxy Note Phones
usertLUIanEfwi
Galaxy Note Phones
According to samsung it does. The note8 is in the list that supports Qi and wireless powershare.
Btw,
I can charge it using wireless charger..
SamsungZell
Galaxy Note Phones
Power share is not a feature of your device.
usertLUIanEfwi
Galaxy Note Phones
I'm a little comfuned...
This is from the Samsung oficcial site - Note8 is in the list of supported devices:
Esso
Cosmic Ray
Galaxy Note Phones
Other user is right. I zoned out entirely. You don't have this feature at all. And yes everyone has an edit button there it's just called button order. If you want wireless powershare you need an s10 line of devices.
KVDV
Halo
Galaxy Note Phones
Note 10 doesn't support power share
DJSTORMX
Halo
Galaxy Note Phones
What that means is if you have a phone from the S10 or Note 10 line then you can lay your Note 8 phone on one those phones and it will charge it as if or was on a wireless charger.
