Bixby Routine Based on Battery Level Not Working
(Topic created: 04-05-2021 05:42 PM)
neilth
Supernova
Galaxy S21
About a month ago I created a routine to turn off a smart plug when my S21U's battery charge exceeds 75%. This routine should run every morning when my phone's battery is being recharged. For some reason, during the last month, this routine has successfully run only twice. How do I diagnose and correct this problem?
neilth
Supernova
Galaxy S21
Several days ago I cleared the Bixby Routine's cache as an attempt to resolve the reliability problem I was having with my battery charging routine. This appears to have solved the problem. The routine is now working properly every morning when my phone's charger comes on and a 75% charge is achieved.
neilth
Supernova
Galaxy S21
You also have a Bixby Routine based on battery level that's not working as expected?
neilth
Supernova
Galaxy S21
I'm going to try and contact Samsung tech support about this issue.
neilth
Supernova
Galaxy S21
I'll let you know the result.
Not applicable
Galaxy S21
Wipe cache partition
User_name
Black Hole
Galaxy S21
report it via members app if you fail to run this routine again
User_name
Black Hole
Galaxy S21
what's a smart plug by the way? is that in the bixby routines?
neilth
Supernova
Galaxy S21
Yes, it's a TP-Link smart plug controlled by their Kasa app.
neilth
Supernova
Galaxy S21
I wiped the cache partition & will see if the routine works tomorrow morning while my phone is charging.
neilth
Supernova
Galaxy S21
Wiping the cache partition did not solve the problem, but wiped out four widgets on my home screen.
