S24 Battery Drain Post-Update
(Topic created: 05-06-2025 04:20 AM)
Jay_Q
Cosmic Ray
Galaxy S24
I updated to one UI7 last night and now my battery while on idle is draining extremely fast.
Had I known this would be an issue I would have never updated to this crappy software.
This is a major issue and like I said I can notice the extreme battery drain while the phone is idle.
If Samsung doesn't fix this issue I will be filing a claim as to me this is now a defective item that they caused.
JesusRamos
Galaxy S24
In my personal experience is doing better since the update
meself
Honored Contributor
Galaxy S24
Some models s25 and s24 and seems s23 are having that issue maybe not all but it's a known issue that should be getting fixed
S76
Cosmic Ray
Galaxy S24
Since the new UI, my battery drops 30% in a hour of light use. S22 ultra
RoguePopcycle
Galaxy S24
Battery is draining much much faster the update! Fix it pls!
Pianodude58
Honored Contributor
Galaxy S24
After an update, your phone has to learn your usage patterns. Give it some time. My phone's battery is now 30-40% better.
Mogay
Comet
Galaxy S24
wait next security patch update
meself
Honored Contributor
Galaxy S24
Should be fix soon
S76
Cosmic Ray
Galaxy S24
Gilly101
Cosmic Ray
Galaxy S24
Can someone tell why this new update is draining my battery and my phone keeps getting hot any fix for this i have the s24 ultra
user5TChAIdiwt
Galaxy S24
Following! Vfold 4 here and this update has cut my battery life in half! Help!
