- Mute
Tuesday
(Last edited
Thursday
by
SamsungJoJo
) in
Ever since the update, I have lost the ability to adjust my sound with the custom volume setting. There is no three dots to hit and there's no floating circle either
Solved! Go to Solution.
- Mute
Tuesday in
Galaxy S25- Mark as New
- Mute
Tuesday in
- Mute
Tuesday in
- Mute
Tuesday in
Galaxy S25If you are referring to the "stickman" floating accessibility icon, you can go into accessibility settings and turn it back on. Settings/accessibility/advanced settings/accessibility settings - choose whether you want it floating or attached to the navigation bar.
- Mute
Tuesday in
- Mute
Tuesday in
- Mute
Tuesday (Last edited Tuesday ) in
- Mute
Tuesday in
- Mute
Tuesday in
- Mute
Tuesday in
Galaxy S25
