- Mute
09-01-2019 07:50 PM (Last edited 12-03-2023 10:20 PM by SamsungChelsea ) in
HD and UHD TVsMy web browser on my Samsung Smart TV will not load any https sites.
This is a fairly new set and has the most current software update.
T-HKMAKUC-1530 (version 1530)
Will there be a resolution for this condition?
I look forward to a positive response, as I will be looking to another manufacturer the for the next set I purchase, if this does not have a positive resolution.
Solved! Go to Solution.
- Mute
09-03-2019 11:03 AM in
HD and UHD TVsYour current software version is not the latest. It should be Version 1540.3. You can find it here: https://www.samsung.com/us/support/owners/product/2015-uhd-smart-tv-ju7100?redir=UN65JU7100
If you can't find the update through your television set, you may have to download it manually. Give this a shot and come back to us if you have any other questions.
- Mute
09-02-2019 08:33 AM in
HD and UHD TVsHave you attempted to unplug the unit for about 5 minutes and replugging it directly into a wall socket?
- Mute
09-03-2019 08:32 AM in
HD and UHD TVsThanks for your response.
Yes, I tried it again last night, hoping that an update had been made and the reboot would finish the fix.
The browser loads http sites fine.
It will not load https sites.
The same “Server not found” message is displayed.
Very frustrating, and something that needs to be remedied by Samsung.
- Mute
- Mute
02-13-2020 09:39 AM in
HD and UHD TVspls clarify how to do the manual update. I have a UN40JU640DF and it shows version 1530. The automatic uodat show this is the latest version and does not give the option to update-
I canmot open web pages. always get
Error message is:
only secure content will be displayed.
please let me know
tks
- Mute
02-13-2020 10:51 AM (Last edited 02-13-2020 10:51 AM ) in
HD and UHD TVsThere is a detailed guide available on the provided link. You can also view it here: http://downloadcenter.samsung.com/content/FM/201510/20151026123952306/2015_TV_Firmware_Upgrade_Instr...
- Mute
02-13-2020 01:20 PM in
HD and UHD TVsHi, thanks for the reply and isnstruction.
The problem is that the samsumg firmware web does not recognize my TV:
Model
UN40JU640DF JU640D
Please let me know how to proceed
tks
- Mute
02-13-2020 01:50 PM in
HD and UHD TVsThe download file is available here: https://www.samsung.com/us/support/owners/product/2015-uhd-smart-tv-ju640d
The install instructions are here: http://downloadcenter.samsung.com/content/FM/201510/20151026123952306/2015_TV_Firmware_Upgrade_Instr...
- Mute
02-14-2020 06:45 PM in
HD and UHD TVsDear sirs
The TV doesnot recognize the upgrade from the USB, and states that there is no upgrade available at this time.
Please let me knw what should we do
Thanks
- Mute
05-29-2020 11:54 AM in
HD and UHD TVsMy tv does almost same thing. Says i have got the latest updated version under the auto update section. Browser isn't working and it says to update tv to latest version.
I noticed the "how to solve" solution that was suggested multiple times didn't work correct?
