S60D Soundbar keeps dropping connection/sound
(Topic created: 10-04-2025 06:29 PM)
Sc0ttyMinZ
Home Theater
I have a Samsung S60D soundbar connected via wifi to a Samsung Q80C TV and use Q symphony. Randomly the soundbar will drop the sound and it will switch back to the TV speakers. If I turn the soundbar off and back on I can connect to Q symphony again, but this keeps happening. TV and soundbar firmware are both up to date. This just started 24 hours ago. Looking for any advise as its getting quite annoying.
MrGhoul
Black Hole
Home Theater
Sometimes, inference can cause this behavior when connected via wifi/Bluetooth. Little while back, my soundbar started dropping out and came to find out it was interference. Also, the soundbar can drop out suddenly if it gets overheated.
Sc0ttyMinZ
Home Theater
Any specific type of interference?
If it got overheated, would it come back on less than a minute later? What would cause it to overheat?
MrGhoul
Black Hole
Home Theater
It could be different factors. My interference was coming from my UPS (power suppy) somehow. Bluetooth is more prone to interference. Sorry I couldn't help you much.
Sc0ttyMinZ
Home Theater
This is helpful, I really appreciate it!
MrGhoul
Black Hole
Home Theater
You are welcome
