Ice bite maker temp sensor needs to be serviced
(Topic created: 10-04-2023 11:16 AM)
userfdJj0c6rTJ
Kitchen
Ice bites maker still makes ice. Is this a software issue? If not can this part be replaced or do I have to replace entire ice maker assembly? I'm guessing the temp sensor is the pack underneath the ice try. Some try replacing this? Part number please.
user_ams007
Planetary Samsung Care Ambassador
Kitchen
To check on the Parts that are needed for Your Ice maker please contact Samsung Directly for that information. Please have your model number and serial number handy when calling, the Samsung support phone number is below
18007267864
You can also check with a local authorized Samsung technician. Use this link to find one in your area: http://www.samsung.com/us/suport/service/location
1 Reply
user_ams007
Kitchen
18007267864
