LP conversion kit for gas range
(Topic created: 08-23-2024 04:51 PM)
Brubasket
Kitchen
What is the correct part number and where can I purchase an lp conversion kit for my Samsung NX60BB871112 gas range? I can’t find the kit anywhere and suspect it may have been lost. Is it hidden somewhere in the range?
Samsung_Moderator
Kitchen
Hello @Brubasket! Thank you for reaching out! I have researched this and unfortunately, I could not find the correct part number for the LP conversion kit. There should be one with your range, and it should be in the drawer or the oven portion. To find the part number I would recommend reaching out to our parts distributer at 1-800-627-4368.
1 Reply
Samsung_Moderator
Kitchen
