- Mute
04-20-2022
09:47 PM
(Last edited
05-19-2022
07:11 AM
by
SamsungJecca
) in
I've connected this cooktop to smart things and I can only monitor temperature or on/off status of the burners? Cannot turn on/off or change burner levels from app?
Solved! Go to Solution.
- Mute
04-21-2022 06:43 AM in
KitchenHi there! I can understand your concern with not being able to control the cooktop through the SmartThings app. I'm providing a link below to information on the features available for a cooktop through the SmartThings app.
https://www.samsung.com/us/support/answer/ANS00060835/
- Mute
- Mute
04-21-2022 08:14 AM in
KitchenCertain Samsung cooktops have a built-in Wi-Fi module that lets you sync the cooktop with the SmartThings app, where you can remotely monitor and control some of its functions.
- IMO "control some of its functions" is deceiving. It could have been "control kitchen timer" because it controls nothing other than kitchen timer
