- Mute
07-17-2026 06:06 AM in
LED and OLED TVsFaulty power board was replaced by Samsung technician, since then a bright uniform round corner rectangular border show up on the TV like the one shown in pictures. What could be the problem?
- Mute
07-17-2026 06:13 AM in
LED and OLED TVs@tskumar It looks like it might be stuck in some type of diagnostic mode? Call Samsung repair center.
- Mute
07-17-2026 06:26 AM in
LED and OLED TVsSamsung tech is not able to figure out the problem, they say that the screen is damaged which I don’t think so. Samsung tech simply suggested to replaced the screen.
- Mute
07-17-2026 06:52 AM in
LED and OLED TVsHello tskumar,
Thanks for reaching out. Support for US products is the focus of this forum. As your device is a non-US model information is severely limited. We kindly suggest that you use this link to look for a support team in the area your product was manufactured in: https://www.samsung.com/visitcountry/
Did you know?
Your region more than likely has a community of it's very own!! Check out the following link and join the community in your region: https://r2.community.samsung.com/
- Mute
07-17-2026 01:04 PM in
LED and OLED TVs
