Control multi TVs from one location
(Topic created: 02-05-2025 08:11 PM)
Johnmik
LED and OLED TVs
Hi I have location with 6 commercial TVs and 20 residential TVs
I need to turn on and off all of them with one action. May be app, one controller or even physical buttons
thank you
realaud
Honored Contributor
LED and OLED TVs
Are they all Samsung TVs? Even if they are not, are they Smart Things connected?  If they are connected to Smart Things, you can control them all from the Smart Things app by putting them all into a group and then you can control them individually or as a group. Smart Things capable devices, usually add themselves to the app, but you can also do it manually by opening the Smart Things app on your phone.
Please mark any response that helped you as your solution.
1 Reply
realaud
Honored Contributor
LED and OLED TVs
