- Mute
06-13-2025 04:54 PM (Last edited 06-15-2025 02:16 PM by SamsungMessiah ) in
LED and OLED TVsQN77S84DAE OLED TV sn <hidden> bought from Best Buy in Jan. Tv delivered in pristine packaging. There were no problems in unpacking or installing. Unit picture and functions are normal. Viewing room is dark throughout the winter but as season changed visible flaws in the display surface became very noticeable. On a line horizontally across the midline of the unit, at least four bumps on the surface of the screen distort the ambient light in the room. With a straightedge as an indicator, the worst protrudes about ⅛” from the mean.
Best Buy defers to Samsung. Samsung support was diligent but unhelpful, particularly in recognizing this was not a damage issue but a manufacturing/ quality control issue. If I use a third party repair service it apparently voids my warranty plus non-warranty repair and travel time costs would be dear.
Display on/screen reflection distortion
Display off/distortion
I’m hoping for reasonable options for repair but live 2hrs N of San Francisco.
Solved! Go to Solution.
- Mute
06-13-2025 05:05 PM in
LED and OLED TVsI apologize for the inconvenience you are experiencing. This is the first time I have encountered this issue, and since you have already contacted Customer Service, I recommend attempting to reach out again and requesting to speak with a supervisor. As this is still within the warranty period, they should be able to send a technician to diagnose the problem. You can also contact a Certified Repair Center for help also with this issue.
https://www.samsung.com/us/support/contact/
https://www.samsung.com/us/support/service/locations/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
- Mute
- Mute
06-14-2025 08:29 AM in
LED and OLED TVsThanks for your reply. I'll give Support another try.
- Mute
06-14-2025 08:31 AM in
LED and OLED TVsThey should have someone in your area that can come out and check it. I had to get a screen replaced on my 65" 2 years ago and the guy drove over 3hrs to get to me had it working in less than 30 mins
- Mute
06-15-2025 02:15 PM in
LED and OLED TVsHey,
First off, welcome to the community. I would like to help get your tv looking the way it is intended to look as soon as possible. I recommend following GaryB82 advice and reach out to us once more.
As we would like to gather additional information, please provide the full model code and serial number of the device as well as your best contact phone number, name, and email.
Send Message to Moderator
If your unit is out of warranty and you would like to receive quotes on service/labor from an Authorized Service Center near you, please visit:
http://www.samsung.com/us/support/service/location
