Photos Looping
(Topic created: 08-17-2025 11:21 PM)
Chris-EBC
LED and OLED TVs
Hi all,
We are using our TV to try and loop some images currently which we have done with a previous model. Once the USB and images are selected and Played, they will loop through 2-3 times then exit out into the image selection screen again.
On the previous model, they will continue to loop until it is exited via remote or the TV is turned off.
Any suggestions? Seems like it would be a simple setting, but can't work it out. The TV was purchased in May 2025.
Samsung_Moderator
LED and OLED TVs
Thank you so much for reaching out! This forum is for the support of US products and customers. We do not have the ability to support models outside of the US. There are differences between the US and International firmware, which we do not have access to. Since your product was purchased outside of the US, please visit the link below for support in your area. https://www.samsung.com/us/common/visitlocationsite.html
Pianodude58
Honored Contributor
LED and OLED TVs
What's the model number?
Chris-EBC
LED and OLED TVs
QA55Q60CAWXXY
Samsung_Moderator
LED and OLED TVs
