- Mute
09-10-2024 04:23 PM in
LED and OLED TVsS90C inability to connect to Spectrum cable box remote, but Spectrum remote pairs perfectly to my other Samsung TVs. I have tried all published codes, discovered what the Spectrum remote detects as the internal code, but will not connect. Is there a Samsung TV setting for the S90C that precludes connection?
Solved! Go to Solution.
- Mute
09-19-2024 11:55 AM in
LED and OLED TVsHello! Thank you for reaching out! I would recommend trying to connect the Samsung remote to control both the box and the TV you can try the following link: https://www.samsung.com/us/support/answer/ANS00089902/. You will also find that it will have options for a third party remote.
- Mute
