- Mute
06-17-2025 07:09 PM in
LED and OLED TVsThe option to select a WiFi network disappeared from my smart tv Network Settings. It momentarily says looking for Wi-Fi Networks but then defaults to WPS only. Have restarted the TV and reset the network settings with no luck. Any suggestions?
Solved! Go to Solution.
- Mute
06-24-2025 07:02 AM in
LED and OLED TVsHi there, Thanks so much for posting about this. I can definitely understand the concern with not being able to connect your TV to the Wi-Fi. I'm providing a link below with detailed information on what steps to take if the TV is not connecting to the internet.
https://www.samsung.com/us/support/troubleshoot/TSG10002209/
Please let us know if this helps.
- Mute
06-18-2025 10:09 PM in
LED and OLED TVs- Mark as New
- Mute
