- Mute
09-25-2025 05:55 PM in
LaundryJust purchased the Bespoke washer/dryer combo and I'm trying to figure out how to enable the Smart Control option on the washer so that we can load up some laundry and start washing it at a later time using the SmartThings app. All of the online instructions I have seen so far do not work.
Washer is connected and I'm able to see status and get alerts, but in the app on the Washer device, there is text indicating Smart Control is off.
Anyone have the secret to enabling this on the Washer?
Solved! Go to Solution.
- Mute
10-16-2025 06:31 AM in
LaundryThank you so much and upon review of your manual from page. 75. It appears you will need to access the quick panel and select the smart control icon to activate the smart control on your washer. I have included the link to assist https://downloadcenter.samsung.com/content/UM/202509/20250926111756839/OID86204_IB_V-PJT_WD8000F-AD_...
- Mute
09-25-2025 06:17 PM in
Laundry- Mark as New
- Mute
10-11-2025 11:12 AM (Last edited 10-11-2025 11:13 AM ) in
LaundryI am having the same exact problem!! We’ve had the vented version of the bespoke washer/dryer all-in-one for about 2 weeks and haven’t found a Smart Control button anywhere on the control panel or in any of the menus while browsing every available option in the interface! What is going on?!? Did they forget to add it or something?? Thinking of calling customer service, because I can’t find answers anywhere. Let me know if you figure it out!
- Mute
10-11-2025 01:45 PM in
LaundryCan you please provide the full model code for you specific unit? It will appear as an icon and not the actual words, you can access your manual here to review https://www.samsung.com/us/support/downloads/.
- Mute
10-15-2025 07:52 PM in
LaundryThe model is: WD90F53AVSUS
- Mute
- Mute
11-29-2025 06:40 AM in
LaundryI have activated Smart Control on washer and my iPhone but cannot control washer from phone
when u do send the instructions to the washer they are always wrong and I have to send at least twice
can you please help
- Mute
10-16-2025 07:37 PM in
LaundryWell that was simple! Thank you for researching that.
- Mute
10-17-2025 07:00 AM in
LaundryYou're most welcome. Enjoy your new washer/dryer!
- Mute
10-21-2025 10:16 AM in
LaundryOn the control panel on the machine you swipe down from the top, the icon for Smart Control is located there. It took me several days to figure this out on my own.
