Samsung Washer Rinse
(Topic created: 04-07-2026 06:55 PM)
Peterwaynekent
Laundry
The Rinse keeps blinking the drawer is full. How do I fix this issue. I have tried resetting the washer and calibrating it. The light still blinks and the rinse does not auto dispense.
Samsung_Moderator
Laundry
Hello Peterwaynekent, we're sorry to hear about the rinsing/ cycle issue being reported and would love to assist. We would need additional product information to be as accurate as possible while we attempt to get this resolved for you as previously mentioned by @Diaboyos.
However, we have these resourceful articles for general assistance:
- Information and error codes- https://www.samsung.com/us/support/troubleshoot/TSG10000997/
- Reset Washer- https://www.samsung.com/us/support/answer/ANS10004807/
- Dispenser Drawer- https://www.samsung.com/us/support/troubleshoot/TSG10002916/
If this information is still not successful with resolving the concern, we recommend having the washer serviced. We have two options to proceed with the service review. 1) Set up the repair request directly using our service link (https://www.samsung.com/us/support/service/) or 2) Private Message any moderator with your full model and serial number
Diaboyos
Honored Contributor
Laundry
Need the model.
Samsung_Moderator
Laundry
