Samsung front load washer code AC4
(Topic created: 06-24-2022 02:38 PM)
Members_TVX27jE
Laundry
  • My Samsung front load washer was put in test mode and code AC4 appeared. Anybody know how to fix it?
Laundry
https://all-errors.com/samsung-washer-error-codes/
It seems like this article after going over it will help you troubleshoot your error and some dyi fixing. I've personally fixed a number of washers and dryers, it helps to know about and get hands on experience.
1 Reply
Laundry
