Easy Setting Box - Setting Screen doesn't Appear
(Topic created: 04-14-2018 01:53 PM)
gmullBlack2
Monitors and Memory
I've run into an problem with the "Easy Setting Box" app where the setting screen no longer appears.
The icon shows running within the taskbar of Win10, but changing of screen layout is hidden now.
Uninstall/Install has not corrected the issue.  Any suggestions would be helpful.
gmullBlack2
Monitors and Memory
Thanks for your suggestion.  Just found the solution after looking at the install logs.
Excerpt:
04/14/2018 16:32:03 Line: 2251;CMagicGridDlg::OnTrayNotification: No Samsung Device Found
Downloaded and Installed Application C34F791.exe and now Win10 recognizes the Monitor.
The "Easy Setting Box" configuration screen is now displayed.
SamsungGill
Monitors and Memory
Have you tried uninstalling, clearing the AppData, then re-installing?
gmullBlack2
Monitors and Memory
Excerpt:
SamsungGill
Monitors and Memory
Awesome! Thanks for the update.
userNYn4DpHbW3
Monitors and Memory
I am having the same issue after upgrading Win 7 to Win 10.
Would you mind sharing how you resolved the issue exactly? Windows 10 doesn't recognize the monitor? I have the CHG90 monitor
SamsungCaleb
Monitors and Memory
Did you make sure to update your monitor's firmware? Also, did you try reinstalling the drivers for the monitor?
You can find them here at this link: https://www.samsung.com/us/support/owners/product/curved-gaming-monitor-chg90-series
