SSD 980 PRO running 1700 MB/s read/write speeds. Even my 960 EVO is outperforming it.
(Topic created: 10-23-2022 10:01 PM)
Drevik
Monitors and Memory
I'm getting really bad speeds on my new SSD 980 PRO. It's running on a STRIX Z270E Gaming Motherboard with a i5-7600k CPU. I don't know if it has to do with running on the 2nd m.2 slot.
I get that it's a 3rd generation m.2, but my 960 EVO is outperforming the new drive.
SapphireXK
Halo
Monitors and Memory
Reading the manual is the best way of figuring these kinds of things out.
"1 x M.2_1 Socket 3 with M key, type 2242/2260/2280/22110 storage
devices support (both SATA & PCIE 3.0 x 4 mode)*
- 1 x M.2_2 Socket 3 with M key, type 2242/2260/2280 storage devices
support (PCIE 3.0 x 4 mode)**"
"The M.2_1 socket shares SATA_1 port when use M.2 SATA mode device. Adjust
BIOS settings to use a SATA device.
** The M.2_2 socket shares SATA_56 ports when use M.2 PCIE mode device in X4
mode. Adjust BIOS settings to use SATA devices."
Tldr yes it's because you used both slots.
1 Reply
SapphireXK
Halo
Monitors and Memory
