how do I tilt monitor model c32t55
(Topic created: 11-03-2021 06:31 PM)
userWInEbYrpaG
Monitors and Memory
I just joined the community folks and this is my first post.
I just purchased a Samsung C32T55 (32" curved) monitor - it works fine but the monitor is tilted backwards. I tried to move it forward but there is no flexibility and it just stays at one place. I am sure there is a way to tilt it forward that I am not aware of - I just don't want to force something and break it.  - Any help will be appreciated.
Not applicable
Monitors and Memory
Hello, I will be happy to help. Your monitor does have a limited tilt range, as shown on page 15 of the User Guide, available at this link.   https://www.samsung.com/us/support/downloads/?model=N0020372&modelCode=LC32T550FDNXZA
Keep in mind that you will experience some resistance from a new hinge, so be careful with the amount of force you use.
1 Reply
Not applicable
Monitors and Memory
