Highlighted
Note 9 S-pen and Note 10 S-pen
JUMP TO SOLUTION
Hi, I was just wondering if anyone who may have a review unit note 10 could see if the new s pen would work and possibly fit inside the note 9. I know the NFC will still recognize it as it will on all note phones but I want to know if it will let you use the remote features and things that the note 9 s pen has. if so I think it would be a good idea to get a replacement s pen for my 9 since the newer one looks to be of better build quality and sturdier.
1 SOLUTION
Highlighted
Samsung Care Ambassador
Re: Note 9 S-pen and Note 10 S-pen
JUMP TO SOLUTION
Hey there @userwC9WaTwFLS, I hope you're doing well.
To answer your question, the new pen DOESN'T fit in the Note 9. The Note 10's S-Pen is much shorter.
I know this isn't what you were hoping for but I hope the answer helps answer your question.
Have a great rest of your day!
Best regards,
Rydah
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "✓ Accept as Solution" button.
3 REPLIES 3
Highlighted
JUMP TO SOLUTION
Best regards,
Rydah
Highlighted
JUMP TO SOLUTION
The note 10 s-pen fits in my note 9 phone.  It fits a little deeper in the housing.  You have to use your finger tip and nail to get it out.  However I actually like that because the pen is more secure. Haven't had any problems getting it out or secured.  Just started test it functions so far it performs all the note 9 features.  Haven't tried its note 9 features.
Highlighted
JUMP TO SOLUTION
Hello! Could you tell us about your experience with Note 10 S Pen on the Note 9? I would like to know if bluetooth commands through the button and gestures work. Thanks!
